Here what im looking for.. budget is around $150-200 (would always like to go cheaper if possible)
My network will be in one LARGE living room.. I could consider going wired and hiding all the wires to the best of my ability but it is an apartment so I am limited. There are no walls that will block the signal.
Ive got 2 pcs (so I will need 2 PC desktop cards or usb cards) Id prefer USB but if they are not as good as the desktop cards id use that.
1 WD-TV LIVE.. It should be next to the router so I will simply run a cable to it.
I want to have wireless-n with gigabyte ports. Ive looked a lot into the 3rd party firmware and that looks great so that is a plus.
So basically what im asking or is.. which wireless-n router should I get?. (will be used for gaming so good firmware is important) and which 2 desktop cards should I get?
