Wireless router Westell
Dps
hi all,
my cousin has a westell model 327w wireless router in her room and im trying to connect to it from my room... i have a wireless card in my pc except i have no clue how to get the access key or the weps or wps whatever security code it is that it requires u to connect..
can anyone help me towards finding this information so i can connect to the internet wireless in my room ?
To get the key you go to your cousins room, ask if it's ok, and if it is, she'll give it to you.
or change it :p
http://192.168.1.254 then click on "wireless" then on the side there be a "configure wireless" make sure that you are on a computer that is connected to that wireless. * i have the same one :D *
edit: the password will show.
