I just bought a DLink DIR-615 N router not too long ago.
I set it up and everything seemed to be working correctly, but sometimes the wireless won't work beyond locally (I have tried restarting the PCs, multiple times even)... What I've had to resort to doing is logging into the router, clicking on the wireless settings and then clicking save settings (even though nothing has changed and it tells me this as well before I proceed) it then takes 15 seconds I click ok and it works fine again... while this doesn't seem to be much, it is just a hassle to always have to do this.
Anyone know why this may be? I have pondered band interference, only using G/B, Channel settings, but can't seem to find an answer.
Thanks for any help you can give.
Tony
Tony
