Hello all,
I was contacted to see if I could help a good friend install a "resort wide" wireless system in a heavly wooded setting. The resort is about .5miles long (2640 ft) and has a ton of trees. In those trees are small cottages that they want to offer wireless access to I was thinking of using some higher end CIsco equipment (1505) and some 14db antenna mounted on their Club house.
I've attached a image of what it looks like This is areial of the location: What do you guys think? Would each cottage have to have a highe end antenna too? I'm thinking yes .
So the main question is, with the right equipment, is it possible?
Here is another photo during fall:
They do have privately owned Coaxial going through-out the resort, would that be a option? I'm thinking distance would be a limitation. Thoughts?
Thanks!
Thanks!
