Wireless network print sharing
OK I just setup my wireless network converted from hard wired. Now my printer will not work from the remote computers. It works fine on the main pc and it is shared. Anyone have any ideas do I have to open a port in the network router or something?
Using XP home sp1 if that helps
opening ports has nothing to do with local traffic. Use the IP in a computer search from your start menu and map the printer that way if NetBIOS resolution isn't working
