Im planning on setting up a wireless network as part of my new comp build. The old machine will go up stairs and will have a "Wireless 54mbps PCI Adapter Card" and the new comp will be connected to the router directly. At present im on UK cable and have a Motorola surfboard SB4100 cable modem connected to nic-card via ethernet cable. Ive no experience of networking so need some advice on parts ive selected, here,s what i plan to use
Linksys WRT54G
Can someone tell me which of these will be the best to use with above router
WMP11 found here
or this one
WMP54G found here
What is the difference between these two cards. Any general advice on this setup would be great. Thanks
Linksys WRT54G
WMP11 found here
Code:
http://www.ebuyer.com/customer/products/index.html?rb=7863582984&action=c2hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=37483
or this one
WMP54G found here
Code:
http://www.ebuyer.com/customer/products/index.html?rb=7863585237&action=c2hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=45602
