I'm setting up a network for training classes I run at my work and have hit a snag. I'm using laptops running Win 2k pro with built-in wireless and a Linksys wireless router that's physically plugged into a Win 2k Advanced Server box that's running Active Directory, and a Novell Netware box that's the Groupwise post office. When I set up the first laptop I was able to log on to the network just fine. Now I've finished imaging all the laptops and configuring the MAC address list on the router.
The problem is that I can't log onto the domain with the laptops anymore. The best I can do is log on using a cached account that was used before when it seemed to be working fine. When I try to log on with a different account I've been getting a "domain can't be found" error. Of course now when I go to check it again it logged on normally after having made no changes. This of course makes me a little nervous since I can't just hope it works when I need it to. The last unsuccesful attempt was made a good hour after the last change made to any configuration.
Signal strength is beautiful (better be, the laptop's only about 5 feet away from the router), and once I logged on with the cached accounts communication between the laptop and the 2 other boxes was just fine.
What should I be looking for here? I know it'll be shots in the dark since it's working now, but does anyone know about common causes for this.
