Wireless n router, wireless g adapter...OMG!
schoenda
I know little about home wireless networking and even less about the various protocols...I would be very thankful for any advice.
I am thinking about upgrading my router to wireless n and upgrading the adapter on my entertainment PC to n as well...trouble is my 2 laptops have wireless g built in. Can I get the benefit of the faster connection between my router (and attached network drive) and my entertainment PC but still use the laptops with wireless g for less intense applications...
Could I watch video streaming in wireless n from my network drive -- router -- entertainment PC while at the same time my wife works on her laptop -- router -- internet in wireless g?
Or would I need a separate second router? And if so how the heck would I hook that up?
Yeesh!
Yes, the wireless N will run at N speeds on those computers who have the N recievers, the rest will run at G speeds.
Keep in mind however that you are using WIRELESS vs wired so your bandwith and relibility even with N isn't going to be as good as a physical connection. Streaming music will be fine and basic video, but if you plan on streaming any kind of HD video content, wireless simply doesn't have the bandwith or reliability that a physical connection has.
Keep in mind also that while "sharing" bandwith with other people has its possible issues. If your wife decides to hit a bandwith intensive site while your watching video, you can expect "lag" or "hiccups" in your streaming, depending how much much of the available bandwith is being used and available
1. I can stream HD crap off my netbook to my comp, on G.
2. I can also stream HD crap off my netbook to my comp, on G while BTing til pages don't load. And it'll still "stream".
3. File transfer is another story, wired trumps wireless.
4. File in question is a 1080p rip of Batman Begins, playing on comp with file on netbook. File size 8GB.
6. Router in question is one simple WRT54G running DD-WRT. I'm doing that right now with active torrent leeching, well at least just now so to make sure I'm not pulling crap outta my ass.
Really the only advantage N has over G is the theoretical speeds and a slight range increase as well. But one thing to remember is "N" is not an official standard yet. It is still draft 'N" mode If I recall. Also in order to run G and N at the same time you need to set up your wireless router to "mixed speed" mode.
I run N in my house.
Usually I am getting about 200+ Mbps.
Just wanted to let you guys know I appreciate your help. Unfortunately wired is not an option for me...file transfer is as I foolishly ended up with a network drive to use as not just a media server but backup for pictures and documents as well...I will probably go to n but without any delusions of sugar plum fairies dancing on my pc.
Pretty much what has already been said, you will be able to connect all your pc's at their full speed. I am on my second wireless router, which is a Belkin N Wireless Router. I like it quite a bit compared to the first one I had, which I used for quite awhile. The other is D-link Airplus Xtreme G wireless router, which isn't that bad. I did have more issues with that than the Belkin I am currently using. Connections would get dropped much more frequently, sometimes there would be a few mins where I could not re-connect. The N router has been much more stable, a lot better range, and all around just much easier to use.
