Aznboy1993
- Nov 9, 2009
Using my recently bought hardware consisting of the D-Link DGL-4500 router and the D-Link DWA-160 usb adapter I did the following tests using LAN Speed Test version 1.1.0 build 97 (latest version at time of writing - 3/21/2010).
The results were very dissapointing... my first run was using G, the second using N.
Wireless G
Wireless N
So according to my tests N is only (at most) twice as fast as G. IMAO it is very dissapoint considering the amount of money I spend on the router and adapter. I might be returning both in the very near future or trying another adapter (D-Link DWA-556) since maybe it's just the USB adapter that plain sucks. But if that fails then I'm giving up wireless altogether and am just going to stretch a 100ft. Cat6 cable to my desktop downstairs... SIGH![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
- The filesize (in megabytes) that I used for the test was 100MB.
- The directory of transfer was to another PC I have connected to the router using a wired gigabit connection.
- The destination computer was idle with a WD Black 1TB 7200 PRM drive and a core 2 duo at 3.6ghz with 2gb of ram running Windows XP.
- The source computer was idle with a SCSI 10k RPM drive and a xeon dual core at 3.2ghz with 1gb ram running Windows 7.
- My G settings I was using were as follows: 2.4GHz, G only, Channel 11, Best (automatic) transfer speed, and WPA2 AES security.
- My N settings I was using were as follows: 2.4GHz, N only, Channel 11, 40MHz, Best (automatic) transfer speed, and WPA2 AES security.
Wireless G
![wirelessgtransferspeeds.png](http://img405.imageshack.us/img405/5913/wirelessgtransferspeeds.png)
Wireless N
![wirelessntransferspeeds.png](http://img714.imageshack.us/img714/6693/wirelessntransferspeeds.png)
