Wireless Media Storage
Ducman69
Anyone have thoughts on wireless storage devices? I assume bluetooth would be miserable performance, and it seems WiFi is the way to go.
Looking for external storage for tablets/phones/etc, preferably something with a car power adapter.
Anyone have suggestions?
I see stuff from cheap HooToos:
http://www.amazon.com/Arrival-HooTo...84067&sr=8-13&keywords=wireless+media+storage
To a little more expensive but capable Sandisk:
http://www.amazon.com/gp/product/B0...pf_rd_t=101&pf_rd_p=1688200382&pf_rd_i=507846
To an expensive but finally decent storage capacity platter based device from Corsair:
There are a variety of these available...I dont recall the models off hand..I had looked into this for the car as well. The limitation I ran into was that none of them had a way to remain connected to the internet. You can connect to the hdd wifi hotspot but then not have internet. If you can live with that.. then there are a few even from mainstream manufacturers. As for the power... you can always use an inverter...even a small cupholder style inverter would be plenty to run one of these.
