Wireless keyboard recommendations
c1001
Need some recommendations on quality wireless keyboards. I had a Logitech DiNovo and liked typing on it. Unfortunately, my 2 y/o likes to pop the low profile keys off with his little fingernails (popped twenty off in under 10 minutes) and broke some.
Since then I tried a Microsoft natural keyboard and the CTRL key starting sticking in less than a week. Plus, it would apparently cause my Gefen IR KVM switch to switch on its own.
I then bought a Logitech MX3200 and it has its own issues. The keys are a bit mushy and don't have that pronounced pressure point to let me when the key has actually been pressed (like the IBM/Lenovo Thinkpad keyboards do). The hotkeys only work sometimes and the PC sometimes stops recognizing the keyboard (and mouse) completely. I also have noticed a bunch of Logi-crap apps now running in my process tab.
If you have any recommendations on wireless keyboards that you really like, please share.
I don't like split keyboards, it can't have low profile keys, and can't be too mushy not too "clicky".
thx
1) *devil's advocate* Have you tried RMAing it, c1001? Logitech is nice about that.
2) Since it's wireless, what about putting it where your little bro can't reach/get it?
3) Remember the keyboard that used to be in the combo with the MX 700? Here is one on eBay. (You can get the keyboard seperate but it's a lot harder to find by itself.) Personally, I loved that keyboard, one of the best I ever used. I have a G15 now, but if I hadn't gotten a G15 I'd still be using that keyboard. I've still got three of them scattered around other computers here. :)
And YMMV, but I bought a refurbished wired version of that keyboard from that seller and have never had any problems.
