Gorankar
- Jul 19, 2000
A friend of mine works from home. Using a Citrix portal to log into a VM that runs outlook, SAP, MS Office, Adobe shit, and IE.
The Problem is that her Logitech wireless keyboard a (K800) does not allow her to log in. It will give a wrong username/password error every time.
The current inelegant solution, is to plug in a standard USB key board to login then move it out of the way and go about her work. This of course is not what she wants. Has anyone run into this b4? Does anyone know of a work around? Kind of an odd issue, but it is 100% reproducible on her win 7 64 bit PC.
I would appreciate any help on this problem, short of "just use a wired keyboard".
