Ok, I am using a 2wire DSL modem, that is wireless, and a dang good one for that matter. It supposed puts out 10x more power for the antenna than a regular wireless router does. Anywhoo, I just purchased a GQ desktop from outpost.com for $149, a very nice setup for the money. I also went to wal-mart, bought a Belkin WirelessG 54mbps card, set it up, but here is the problem.
The DSL modem is in the next room, basically one wall away( thats all thats blocking). I have this new computer on the other side of the room of the room next to the DSL modem, so call it 20ft MAX with one wall of interference. The antenna on the computer is on tha backside, so the signal also travels through the computer too, not sure if the aluminum is that much interferring. Now, I still get a great signal, 80-92% to be exact. However, here in lies my problem. When I leave the computer on, which is what it is intended to be used for is a server for FTP, havent done it yet, it looses connection, and upon coming back to the computer, it shows that its not connected to the wireless network, wont show when I refresh to find a signal, so I have to restart. What the heck is causing this? I have tried different channels on the DSL modem itself.
Here is another thing, my main rig, the one I am on is sitting 3 feet from the one computer that keeps loosing connection, but I have an extended Directional antenna hooked up to it, pointing directly towards the direction of the DSL modem, getting near 100% connection. This computer NEVER looses connection, so what gives, do I have something setup wrong on the one that keeps loosing connection?
Please help if you can, inquiring anything that might be the problem here.
