Wireless Internet Connection Issue
JC0724
My wireless connection to my internet just stopped working. I have no idea why.
I noticed my VAIO Smart network wireless switch is not cut on.
When I open up the VAIO smart network to cut on the WI FI(that is current showed as dis connected, every time that I click the on switch or any switch in the Manuel a little box pops up and says "Turn the WIRELESS switch on the VAIO to ON and then try again".
Any ideas how to fix this and/or get my wireless connection back working again?
Try cleaning out and reloading the driver software.
If that doesn't work and you don't want to spend a lot of time the easiest thing to do is to get a really small USB wifi for $10. They are so small that you can just leave them plugged in, only downside is you "lose" a USB port, but if you are like me then you aren't using them all anyways.
http://www.amazon.com/gp/product/B0..._m=ATVPDKIKX0DER&pf_rd_r=13C3QAVRA79F1R2PTTNC
I have a sony VAIO laptop, windows 7
How do I clean out and reload the driver software?
