candy76man
- Jun 9, 2003
I have a logitech wireless gamepad that I am using on my system....the problem i have is that windowsxp pro acts like nothing is plugged into the usb port I have the gamepads reciever on after a restart....I have to unplug it and plug it back in to make it work, and after that it's fine untill i restart the computer again and then i have to do it again.
I have a thrustmaster wireless gamepad as well and it doesn't have this problem....also I can plug the logitech controller into my other computer and it doesn't have this problem so thats why I don't really know if it's the motherboard or the controller or windows causing the problem?
If anyone has any ideas I'm all ears
thanks
specs.
Abit KR7 mobo
512 megs ram
1900+ cpu
ati radeon 7500 vcard
nothing is overclocked and the system is stable, all usb ports are working with no problems..I have the controller reciever plugged into a back panel port....I've gone through the bios and found nothing obvious that might cause the problem I'm having.
thanks
specs.
Abit KR7 mobo
512 megs ram
1900+ cpu
