I am looking at putting an outdoor access point on top of the main building and spreading that signal about 500 feet to a bunch of cottages in an area.
------------------------------------Cottage-----------Cottage-----------Cottage-----------Cottage
Main House-------------------------------Cottage-----------Cottage-----------Cottage
|----------------------------------------- 500 FT -------------------------------------------------|
That is the general layout. Budget is under 2grand.
I think for the price each machine will just join the same wireless SSID. I do not think we can get it so each computer pretty much joins its own network and cant browse other machines. I do not think we can get captive portal in this price.
What I have came up with after talking with a local distributor of some wireless gear
2 x 30 Degree Antenna on roof - http://www.gnswireless.com/GNS1403_WiFi_Antenna.htm
Mount for roof - http://www.gnswireless.com/GNS1433.htm
Access Point - http://www.gnswireless.com/GNS1673.htm
Amplifier - http://www.gnswireless.com/GNS1460.htm
Router - RV042
gonna run a 50ft cable to roof, put splitter up there, rest of gear in basement with a small battery backup unit.
quote was about 1100-1200, then gonna apply as a VAR and good to go.
any suggestions?
Will be deploying AP Isolation
Router - RV042
any suggestions?
