wireless desktop wont connect
Wheresatom
Hey everyone.
This is my first post on this forum. It looks like this site has a lot of really smart people. Lets hope someone has an easy fix for my problem.
I bought this cordless desktop system from newegg last week and it arrived promptly on Tuesday. It is a logitech MX 3000 laser desktop. I got the system at work because I spend a lot of my time there on the computer.
Well, I have spent about a half hour per day the last 2 days after I got off the clock trying to get that thing to connect to the computer to no avail. I loaded the setpoint software, and plugged in the USB, hit connect on the receiver and mouse, and the same with the keyboard, and neither works. I have some connectivity to the receiver with they keyboard as I can make the LED under the F mode light up and turn off. But that is the only proof I have that my keyboard has attempted to connect. There is no sign of life from the mouse.
I tried connecting the desktop with the old keyboard and mouse not connected, and thats a no go. I also tried with them connected, still no good. I am running out of ideas. I talked on the phone with the logitech people a bit today, and he got me to download the driver from their website, and that did not work either. Can anyone post a screenshot of the logitech software menu open if they have theirs running? He was referring to buttons that were not showing up on my screen at all, so I am wondering if the problem is in the driver.
Also, another option for the issue might be that there is too much interference. The firm I work at has I think 4 cordless phones, and another logitech cordless desktop that run on 2.4 GHz along with this desktop system. Will I ever be able to get this thing to connect with all of that in the office?
This is getting long enough, so if anyone has any suggestions I would really appreciate the help. I love the keyboard just from typing on it a bit with it not connected to anything. They keystrokes are the definition of smooth. The mouse doesnt feel half bad either so I would really like to make this thing work.
Thanks in advance for your help.
Doesn't really sound like a driver issue if it never worked from the word go, but, things get messed up.
I'd recommend you completely uninstall the drivers, shut down, then hook up your old devices, and boot, then follow your instructions ( should be install the drivers, then plug in the devices ) this should work.
Would also help if we knew what operating system you were running :)
if you're running Vista 64 bit make sure you get the 64 bit version and not the 32 bit version of set point, and likewise for windows XP 32/64
http://www.logitech.com/index.cfm/downloads/software/ZA/EN,CRID=1796,contentid=10752
Hope that is what is causing it, I doubt it would be the interference from another mouse or cordless phones, I've never had any similar problems.
Ok, I am back at work, and have uninstalled and then reinstalled the driver. Still no go.
Is this what the setpoint software is supposed to look like when it has loaded?
The guy on the phone yesterday was indicating there would be a button for Mouse and Keyboard that I am not seeing. It sounded like it should be next to the Tools tab up top.
Ok, update.
I got tired of watching my new keyboard and mouse collect dust today, so I decided to try it out on one of my co-worker's desk while he was gone. That thing installed in about 2 minutes on his computer, wouldn't ya know. The above image is not what the setpoint looks like as there are 2 tabs, one for mouse, the other for keyboard.
Now I am wondering:
1)Do those tabs maybe only show up if the hardware is recognized by the computer?
2)Being the problem is likely in my computer, does anyone have suggestions on what the problem is? The USB ports on the front of my machine do not work from what I can tell. I plugged the old mouse into the front and it was a no go. But using the old mouse's USB port the new keyboard/mouse still do not connect.
Any thoughts?
