wireless card not getting signal
Sizlak
ive got a linksys 802.11g/b router. ive got one system wired straight to it and a laptop connected wirelessly. both of those work fine. when i try introducing a 3rd wireless card it doesnt detect the router signal at all. ive tried several different wireless cards/adapters and none will see the signal. im sure i havent turned on mac filtering or anything like that.
to put it simply this laptop wireless card is the only thing that detects the network. i reset the router to factory defaults and still no help.
any suggestions are greatly appreciated
Can you provide a bit more information on the new system you are trying to connect wirelessly? Hardware? OS?
Sounds like the computer. If 2 out of 3 can connect, and on the troublesome computer you try 2-3 Different wireless cards then I would investigate that computer.
