So I recently upgraded the firmware on my WRT310N. Right after none of my wireless clients could connect while the router was set in "auto" channel mode. If I manually set the channel in either 20Mhz or 40Mhz and a upper range channel number (5-11) they connect. My Intel 5300 AGN card in my Dell e6400 won't connect above 54g. I have a WMP600CM wireless N PC card in my wifes 3 year old Satelite A105 that connects at 160-240Mbps. If I set the transmission rate on the router to 160Mbps the e6400 shows connected at 130Mbps but I can't get more than 40Mbps or so. Any one have this issue?
I am going to try loading a different driver and if that doens't work rolling back the firmware to see if that helps. There is only one other router in my neighboorhood thats N and several other G routers mostly running on channels 11 or 6. The strongest being 3 on channel 11.
