Hey all. I've got the following setup:
2 computers upstairs w/ the cable modem, and 2 comps downstairs.
Right now, the 2 upstairs comps are the only ones online, hooked up through a standard non-wireless linksys router, and the others aren't on connected.
I'm thinking of getting a wireless router. I wanna put the wireless router upstairs for the 2 comps, and bring the wired router I have now downstairs to connect it to the 2 comps, and connect a wireless access point to it.
Will that work? If I disable the routing function of the wired router, in effect making it a switch, will the access point work fine with the wireless router upstairs?
