Wireles LAN : PCI or USB?
Snooble
Hey all,
I'm going to buy a wireless ethernet adaptor and I was wondering if I should snag a USB or PCI. I'm pretty smart about drivers, etc, so I just want to know what the downfalls of them are.
Only reason I want to go wireless is so I can have a lot less cable around and hopefully get a better speed from my router (since it'll be closer to the phone jack)
Thanks
I think the USB Wi-Fi addapters are more meant for laptops or people that want wireless without opening their desktop.
If you can do it yourself, get the PCI.
I disagree. I had several wireless cards and USB adapters and the USB adapters performed either just as well or better since you can move it to a better USB slot, or simply turn the antenna the way you want.
I'd get the USB stick.
Yeah and you can just used USB extension cables (or repeaters) to place the antenna pretty much anywhere. I guess you can get antenna kits for PCI cards, but they are more expensive.
I have the Dell E2007 LCD widescreen with the USB ports on the side...would that work for the USB LAN connector? :D
I don't see a reason why it shoudn't work. If it's USB 2.0, you're good to go.
Recently did some testing with my own PCI and USB adapters and found the USB adapter to actually have a better connection. Just FYI.
