Jun 27, 2013 #1 F Faction The Chairman Joined May 8, 2006 Messages 5,460 Do they even exist anymore? realistically I just need something to handle DHCP, ideally just a single WAN and a single LAN to connect to my 8 port gigbit switch anyone point me in the right direction?
Jun 27, 2013 #2 G goodcooper [H]F Junkie Joined Nov 4, 2005 Messages 9,771 ubiquiti edgerouter lite... but probably overkill....
Jun 27, 2013 #3 W wizdum [H]ard|Gawd Joined Sep 22, 2010 Messages 1,943 You could get an edgerouter or pfsense box off eBay. I dont know of any consumer grade LAN only routers.
Jun 28, 2013 #5 P peanuthead Supreme [H]ardness Joined Feb 1, 2006 Messages 4,699 If this is for a residential install, then I typically just get whatever wireless router off of the shelf and disable the radios if they are not needed.
Jun 28, 2013 #6 M maw Supreme [H]ardness 2FA Joined Sep 27, 2000 Messages 4,135 Just buy a regular wireless router and disable wireless transmission in the settings.
Jun 28, 2013 #7 R RocketTech 2[H]4U Joined Oct 7, 2009 Messages 2,359 TP-Link has a couple. Also, many modems will work as a router.
