wired router 4 gaming
cartier007
can anyone suggest a wired router that will be great 4 gaming. i just need a router so i can keep my laptop & desktop internet connected. I am not sure about the speed needed, can any1 help me out?
cartier007 said:
can anyone suggest a wired router that will be great for gaming. I just need a router so i can keep my laptop & desktop internet connected. I am not sure about the speed needed, can anyone help me out?
Ive never used any of these routers, but from what ive read, they seem to be decent.
http://www.tomsnetworking.com/2005/03/04/review_dgl4300/
http://www.practicallynetworked.com/review.asp?pid=484
Though, those are $100+ routers. You will probably be fine with something cheaper, but I cant offer any advice on the low end ones.
the lynksys is 70 bucks at J & R http://www.jr.com/JRProductPage.process?Product=3117612
im also looking for a router that's how i know.
is that router a true 10/100 on both ends? im asking because the BEFSR41 apparently caps at 10 on the WAN side. can anyone verify on a wired that wont cap that low on the WAN side?
