What are you a gay fish?
Sorry, could not resist the south park reference.
lulz.
see dash's post
mine are labeled 'fish stix', got them at menards I think
Nice setup. Ive been thinking about doing the same for a house I am buying. Though I plan on only making 4 drops in the ML, maybe 2 in each bed room. What did you use to fish the wires through? any tips or suggestions?
I have a 25' FiberFish, a 3/16 fiberglass rod in a coil. I mostly use it in tight locations, such as under desks or in closets where a longer rod isn't convenient. I don't see it as a necessity, just handy at times. Where a longer fiberglass fish tape would beat rods is for use in conduit with bends- I find the bends puts too much strain on the joints. It is not common to run data cabling in conduits, so I guess it comes down to circumstances.
That's the hard way still.
Using light string, and toilet paper. Make a ball a fluffly big one, then tie string in the center. Put it in one end of the pipe. Go to the other end with your vaccuume, and turn it on. POOF it should suck the tp and string right to yaI do it all the time..
Sounds great for empty conduit, but partially filled conduit might be another matter... You'd just wind up with a mess. Not to mention if I showed up to the job with a roll of toilet paper and string, I might not be coming back.
