I have been getting weird crashes with the computer with these Visiontek cards (7870 HD 2x GHz Edition 2GB mem) the PC would get black or Grey crash screens some times with stripes when I would reset the PC I get no error report or min dump so I suspect the cards one witch I have already RMAed anyhow that't not why I'm here.
I have had this happen every time I move these cards to a different PC, first I uninstall catalyst then use driver fusion to clean up before I remove the existing cards from my main rig or even when I put them back in there rig.. ok boot the PC with the 2x 7870's install drivers like normal. Now normally I would be ask for a reset but no request is given so I reset my self get back in to the OS but everything is wrong I have only one monitor out of 3 working like I have not drivers and I can't launch catalyst because "there is no AMD hard ware for Catalyst to make changes" now this is the messed up part if i shut down and pull off the Cross fire cable and put it back on restart the system it works no problem now I have done this 3 times and every time I have to do the same thing with the crossfire cable I have even replace the cable twice thinking that it was because of a bad cable but no this is directly something with the GPU.
now has any one seen or heard of this and is it a tell tail sing of a bad GPU I need to figure this out soon my warranty runs out at the end for November and I know how difficult it is to get visiontek to do anything regarding a RMA or is this just a quark with the 7XXX series that I never have heard about.
also any tips about the Grey/Black/Blue crash screen with don't seem to crash the whole computer (Grey screen once with youtube still playing audio and yester day a blue screen and I had my mouse cursor but not task manager)will be very help full
Before any one gets on me for asking I have googled the crap out of this problem for days to no avail I don't know if im asking the wrong questions or no one has ever had this issue but I'm hoping some one will have a little info about my problem till then I;m going to use these card in my main rig and see if I get crashes and if I do I will try to narrow witch card it is.
EDIT: Forgot to mention I disabled ULPS to see if it solved my problem but I seem to still get the crashes no the problem rig just not as frequently
Thanks for any help.
Main Rig:
MOBD: ASUS P8Z68 Deluxe
CPU: i7 2600k @ 4.2GHz stable
Mem: 8GB corsair vengeance
PSU: Antec Gamer Power 1200Watt
GFX: 3x 6950's (currently 2x 7870)
HDD: Intel 120GB SSD + Storage
Problem Rig:
MOBD: Asus P8Z77-V LX
CPU: i7 3770K @ 3.5GHz stable
Mem: 8GB corsair vengeance @100MHz 1:1 Ratio (the MOBD had a problem with the Ram at default speed 1:1 ratio seemed to work good with no more BSOD 8 months+)
PSU: Antec Gamer Power 900Watt
GFX: 2x 7870's (Currently 2x 6950's)
Main Rig:
Problem Rig:
