Wire sleeving [HELP]
So I have the antec minuet case, the cables are messy in the case. What tools do I need to remove the molex and the other connectors? Also, is there a guide here that tells how to sleeve the wire effectively? Money is not an issue since I don't expect spending over $60 for sleeving tools/supplies. Any type of help is appreciated.
Thanks,
Mark
I have a partial modular Corsair 750 PSU. Frozen CPU has fantastic cable sleeve options, some don't require removing the molex connectors. I personaly used spiral wrap since it can be used over and over with changing hardware / additions and doesn't require the removal of connectors.
I personally use a flat head jewelers screwdriver and a pair of tweezers that I filed down... works like a charm every time ;)
