Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I have a socket 370 Pentium 3 system that can't overclock due to limitations in the BIOS. Is there a way to set the multiplier manually, for instance like the wire mod used on Athlons?
Like the above guy said, its not possible. Intel hard locked theirs, so its not changeable. The only ones that have changeable multis are the engineering samples sent out to people like [H] when they do previews/reviews on them.
