Wire Management
BoyBlunder
alright well, i've tried zip ties, and now I'm using duct tape. i thought it would make the inside look nice, but it still doesn't. i see rigs on here with virtually no wires, and i want to know how they do it?
tips appreciated :D
Originally posted by Bruce
Run your cables behind the motherboard.
exactly
also:
*sleeve your cables (PSU, IDE)
*turn your HDDs "face-forward" if you have a drive cage that permits it
*get rid of your floppy drive
*use rounded ide cables
rounded ide cables isnt the best to use.
for me, flat cable works best since i can fold and hide them away
I agree, I'd use flat cables as well. I made a sick rig for someone that had no wires showing at all except the ATX mobo connection. (and even that one was just a peeker).
As a side note, does anyone know how the new Mac G5's get away with looking like they don't have wires?
-SEAL
Yea the 1337est of the 1337 use flat wires such as Username. Thats so insane how me makes it look like absolutly nothing is plugged in.
actually mine isnt the cleanest.
i saw one case posted in [H] around 3 years before with ultra clean cables. every power cables are directly soldered directly to the pcb. i can't find it anymore:(
its lian li case if im not mistaken with the side panel replaced with plexi. damn clean i must say
anyone remember that?
Well once you start soldering the power right to the pcb... thats just insane. But for using normal cables.. ur the man
What I hate is the round ATA cable that came with my board. Its a really nice cable, but it has a connection in the middle and a connction on the end, which is hard to hide.
Meh, I use round cables and just some tubing on all my power supply wires. It's not super clean, but it looks neat. I ziptied down every wire I could, and most of my cables run behind drive cages. Took me less than an hour to do, and it's clean enough so that you can see the goodies inside.
My main rig was is pretty clean right now, but when I get my second SATA drive it'll be even better SATA really helps cable management. The new Machine I built last night is SUPER clean aside from the wire from the side panel case fan (but I got a solution for that.)
I use several different things for cable managment, Velcro, Split Loom, and good 'ol Black Zip Ties in different sizes.
Only good thing about rounded cables are their length, I also think they suck after a little incident involving a $60 DVD Drive to find out the rounded cable was the culprit. Ribbons are fine as long as they are folded.
is it possible for me to run the wires behind the mobo while the mobo is screwed in? or will i have to unscrew everything?
depends on the wire:)
but most of them requires you to remove the mobo first
-SEAL
Rounded cables can work really well for some drives, flat cables are often better for CD-Rom drives because airflow past those drives is unimportant.
I thought they just left cables out of the G5s because cables aren't "trendy". :D
