Wire Management Tips - Antec 300
mattm
Got my rig all put together and before i begin to OC I'd like to get all the wires out of the way. Can anyone (esp with the same case) provide tips/pics on how they did it? I'm guessing electrical tape, and running slack cables along the sides taped. Thoughts?
I usally run my cables behind the back of the MB tray if your's is lifted that might be an option. if not black zip ties always work ;)
I haven't totally ran my cables on my 300 yet and I may still do some cutting :D
I did however pull all of the front ports and led cables through a small hole in the upper corner of the case to run them down behind the 5.25 bays and the hard drive bays so they are as hidden as possible when viewing with the door open. The hole is pretty small, but with some patience you can get all the cables through there.
