Wire management in a CM Stacker
GrimWD
I'm wondering how do you guys do it. Between the front port wires, the power cords, the fans and the sata cables I have a wiring nightmare where i literally have a wall of cables stuffed above the hd cage.
I want some extra cooling in my case and I figured out the fan bracket I removed from the side panel to make the cpu heatsink fit, mounts into the front of the case but now I need to find a way to get these wires sorted out so I can make the most of it.
I have the original Stacker and I just run everything that I can behind the mobo tray and the hard drives. Its not easy to hide many cables in this case when you're running 6 HDs and a CDrom like me. The watercooling makes it even more messy.
You just kinda have to accept that you can't hide everything.
I have 8 hard drives, a creative audigy drive, optical drive, raid card, fan controller, 11 fans, etc...
There is NO WAY I can hide them but I can try and make them look decent.
Here is my go at it:
