Wiping/reformatting hard drives
Flogger23m
Just wanted to get your input before I do anything.
Going to be using my Win 7 Pro upgrade that I have been storing for months.
Currently, I have a 1TB drive with Vista installed. I also have a 750GB drive with Win 7 RC/Beta/whatever installed.
First thing I would like to do is wipe and reformat the 750GB. I'd want to make it a slave/data drive, so I can copy all of my data off of my 1TB Vista boot drive. How would I do this?
Then once that is done and I backup all my data on the 750GB and DVDs, I will wipe my Vista drive, and install Win 7 upgrade on it. This should work, right?
Any tips would be helpful.
When you go to install Win 7 it will ask you where you want to install it. You can delete the partitions and create a new one in there on either drive. That will clear the the drives. If you REALLY want to wipe the drive you can download any Linux Live CD such as PCLinuxOS (I like there Disc viewer) or Linux Mint. These are fully operational OS's that run from the CD-ROM. Then google "dd /dev/zero/". Thats a way to write all zero's to your harddrive....nothing will survive that.
Theres also badblocks and several wipers if you want that. I like using badblocks to have it do a 4 pass destructive read / write test. After that your data is wiped and you are sure that your drive is functioning. Check the smart data before and after to verify loads of sectors are not being remapped.
Ok, thanks for the info.
As for my 750GB drive that I want to turn into a slave drive, can I reformat that into a slave from Vista?
Say I hook it up as well as my 1TB Vista drive, boot form the Vista, and then reformat the 750GB to be a slave?
Yep, that'll work.
I use CCleaner to do a 3 pass wipe/erase. You can do even more if you want :eek:
Yeah, I am just trying to remove everything and start from scratch with Win 7. I have so much junk on my drive, and I'll never willingly uninstall/delete it unless I start from a fresh install.
I am guessing just doing a reformat is good enough for that?
