Wiping a couple old raid drives
bigdogchris
I have a couple drives pulled from a server. The drives were configured in RAID mode. I do not have access the the server anymore, so I threw them into another box to just wipe them. Of course the drives are not detected since they are configured for the other raid controller. I didn't expect them to come up but I thought I would try anyways. In the past when I've had this issue I always just threw them back into the old server, removed the drives from the array, and then was able to detect them on other systems. But since that box is not available anymore I'm a little stuck.
Is there any type of application that can detect other raid controller drives that are present so I can delete the raid configuration and detect/wipe the drive?
Thanks.
I just had to wipe 22 dell servers last month (old leased machines). I took the drives 10 at a time popped them in to one of the machines, went through the raid controller, deleted the foreign config and set each drive up as an raid-0 of one drive each. I then used dBan to wipe the drives.
Depending on your raid card you should be able to clear the old/foreign config and set them up.
Ahh OK, I may have to boot into the config utility. I just didn't want to down the server in the middle of the day to check.
Thanks.
or
assuming regular SATA,
you just attach the HDs to the a external SATA to USB/eSATA dongle and use DBAN to wipe the data
if your HDs are SAS, you already got the answer from on someone reply on this thread .
