I have a windows XP pro SP1 cd that has worked many times when formatting my computer but now when i try and load it, in the bios screen, with a blank HD, it says 'pci.sys is midding'
or many of the setup files cannot be found when tryign to copy them over after the format. the cd is perfectly clean and ive used several cd drives, a samsung 8x dvdrw, 48x cdrom, 52x cdrw, etc. no worky anyone have any ideas ?
system specs are in sig
