WINXP PRO: File Sharing Permissions
ezkim0x
http://www.microsoft.com/technet/prodtechnol/winxppro/maintain/filesharing.mspx
I found this and tried it, but I don't even have the security tab.. where it says Security I just have Sharing.
What I'm wondering is how I set permissions so other computers on my network have to enter a login/pass before they can access my shared files/folders.
I have a win2000 pro computer on my network and before you can access the shared files on that computer it prompts you to enter in the username/pass of the computer before continueing.. That's what I'm wanting to do on my winxp pro computer if possible.
But I can't figure it out.. also i'm logged in under (computer administrator) account.
I bet you only have simple file sharing enabled...
Start windows explorer ->tools -> folder options-> view
scroll all the way to the bottom
uncheck use simple fire sharing
Pretty sure its what he said.
It shows the security tab now, so that was it.
But is there a way so I can make it so it prompts you for a login name/pass? if you aren't logged on one of the accounts that has permission?
Like if I click on my win2k computer it prompts me, and i have to enter my username/pass for that computer. then it gives me access to the folders.
ya, i want to set admin on a folder, but i want to be able to type that in from my 2k Comp upstairs. How do i go about doin this?
just make sure your current user account isnt on the other computer when you access it and it'll ask you for an account and pswd
and in the case it is ? :(
If the user account on the remote system has a valid ACL for the shared directory then it's going to get in over the network without prompting for a password. IIRC, since that account would authenticate over the network as soon as you touched the remote box you wouldn't even be able to get the prompt for l/p...someone feel free to correct me if I'm wrong.
What exactly are you wanting to accomplish? I understand that you want to share folders and limit access to your files in some way. Why are you not in a domain environment?
Havent got to it. :D Im at jome ;) I will setup a server here soon, as soon as i redo this computer room
If that ACL has the account your logged in with locally then you've already authenticated. No reason to be prompted again. If you want to be prompted for some reason then don't put your account on the remote resources ACL or share permissions tab (though the share permissions should be using the everyone and full control permission)
Unless I am just completely misunderstanding what your asking.
