Winxp/linux w/samba network
RPhArrow
Need a little linux help here.... I'm folding fine on several linux (Fedora Core 3) boxen, but cannot seem to get samba set up correctly using gnome configuration tools (yes, I RTFM to death...) . I would really like to use EMIII to monitor my linux folding -- I have this feeling that I'm overlooking something really obvious, but my WinXP user is just not being permitted access to the linux boxes (so I don't even GET a chance to see the shares).
--- I'm not asking for a hand-holding conversation, just some pointers in the right direction.
Fold ON !
11 GHz & climbing
DR_K13 said:
What have you done so far and where are the hang ups?
1. Windows network working fine , all XP machines communicating
2. Linux boxes all connecting to internet through NAT router using DHCP, named each linux box & assigned them to workgroup named same as windows workgroup.
3. Samba server installed on linux boxes
4. Created samba user (same user name as my winxp login)
5. Created samba share for folder named "Folding" in linux user's home directory
6. made that share read/write for "All"
7. I go to XP box , try to create Network Place , the linux boxes show up in the workgroup, but give me this msg: " \\xxxx not accessible. You may not have permission.....etc. Network path not available."
Is this enough info to help at all ? Gotta run to work now, will check back this evening.
Here is my smb.conf file that I plug in on every samba boxen I have, and just change the workgroup name. You may want to give it a try. It was created in Debian a couple years ago, but it worked fine on my newer Gentoo, FreeBSD, and OpenBSD boxen as well.
Code:
# Sample configuration file for the Samba suite for Debian GNU/Linux.
# $Id: smb.conf,v 1.2.4.6 2002/03/13 18:56:16 peloy Exp $
# This is the main Samba configuration file. You should read the
# smb.conf(5) manual page in order to understand the options listed
# here. Samba has a huge number of configurable options most of which
# are not shown in this example
# Any line which starts with a ; (semi-colon) or a # (hash)
# is a comment and is ignored. In this example we will use a #
# for commentary and a ; for parts of the config file that you
# may wish to enable
# NOTE: Whenever you modify this file you should run the command
# "testparm" to check that you have not many any basic syntactic
# errors.
#======================= Global Settings =======================
[global]
# Change this for the workgroup/NT-domain name your Samba server will part of
   workgroup = workgroup
# server string is the equivalent of the NT Description field
   server string = %h server (Samba %v)
# If you want to automatically load your printer list rather
# than setting them up individually then you'll need this
;   load printers = yes
# You may wish to override the location of the printcap file
;   printcap name = /etc/printcap
# 'printing = cups' works nicely
;   printing = bsd
;   guest account = nobody
   invalid users = root
# This tells Samba to use a separate log file for each machine
# that connects
   log file = /var/log/samba/log.%m
# Put a capping on the size of the log files (in Kb).
   max log size = 1000
# If you want Samba to log though syslog only then set the following
# parameter to 'yes'. Please note that logging through syslog in
# Samba is still experimental.
;   syslog only = no
# We want Samba to log a minimum amount of information to syslog. Everything
# should go to /var/log/samba/log.{smb,nmb} instead. If you want to log
# through syslog you should set the following parameter to something higher.
   syslog = 0
# "security = user" is always a good idea. This will require a Unix account
# in this server for every user accessing the server. See
# security_level.txt for details.
;   security = user
# You may wish to use password encryption. Please read ENCRYPTION.txt,
# Win95.txt and WinNT.txt in the Samba documentation. Do not enable this
# option unless you have read those documents
   encrypt passwords = true
# Using the following line enables you to customise your configuration
# on a per machine basis. The %m gets replaced with the netbios name
# of the machine that is connecting
;   include = /home/samba/etc/smb.conf.%m
# Most people will find that this option gives better performance.
# See speed.txt and the manual pages for details
# You may want to add the following on a Linux system:
#         SO_RCVBUF=8192 SO_SNDBUF=8192
   socket options = TCP_NODELAY
# --- Browser Control Options ---
# Please _read_ BROWSING.txt and set the next four parameters according
# to your network setup. The defaults are specified below (commented
# out.) It's important that you read BROWSING.txt so you don't break
# browsing in your network!
# set local master to no if you don't want Samba to become a master
# browser on your network. Otherwise the normal election rules apply
;   local master = yes
# OS Level determines the precedence of this server in master browser
# elections. The default value should be reasonable
;   os level = 20
# Domain Master specifies Samba to be the Domain Master Browser. This
# allows Samba to collate browse lists between subnets. Don't use this
# if you already have a Windows NT domain controller doing this job
;   domain master = auto
# Preferred Master causes Samba to force a local browser election on startup
# and gives it a slightly higher chance of winning the election
;   preferred master = auto
# --- End of Browser Control Options ---
# Windows Internet Name Serving Support Section:
# WINS Support - Tells the NMBD component of Samba to enable it's WINS Server
;   wins support = no
# WINS Server - Tells the NMBD components of Samba to be a WINS Client
# Note: Samba can be either a WINS Server, or a WINS Client, but NOT both
;   wins server = w.x.y.z
# This will prevent nmbd to search for NetBIOS names through DNS.
   dns proxy = no
# What naming service and in what order should we use to resolve host names
# to IP addresses
;   name resolve order = lmhosts host wins bcast
# Name mangling options
;   preserve case = yes
;   short preserve case = yes
# This boolean parameter controlls whether Samba attempts to sync. the Unix
# password with the SMB password when the encrypted SMB password in the
# /etc/samba/smbpasswd file is changed.
;   unix password sync = false
# For Unix password sync. to work on a Debian GNU/Linux system, the following
# parameters must be set (thanks to Augustin Luton <aluton@hybrigenics.fr> for
# sending the correct chat script for the passwd program in Debian Potato).
   passwd program = /usr/bin/passwd %u
   passwd chat = *Enter\snew\sUNIX\spassword:* %n\n *Retype\snew\sUNIX\spassword:* %n\n .
# This boolean controls whether PAM will be used for password changes
# when requested by an SMB client instead of the program listed in
# 'passwd program'. The default is 'no'.
;   pam password change = no
# The following parameter is useful only if you have the linpopup package
# installed. The samba maintainer and the linpopup maintainer are
# working to ease installation and configuration of linpopup and samba.
;   message command = /bin/sh -c '/usr/bin/linpopup "%f" "%m" %s; rm %s' &
   obey pam restrictions = yes
# Some defaults for winbind (make sure you're not using the ranges
# for something else.)
;   winbind uid = 10000-20000
;   winbind gid = 10000-20000
;   template shell = /bin/bash
#======================= Share Definitions =======================
[homes]
   comment = Home Directories
   browseable = no
# By default, the home directories are exported read-only. Change next
# parameter to 'yes' if you want to be able to write to them.
   writable = yes
# File creation mask is set to 0700 for security reasons. If you want to
# create files with group=rw permissions, set next parameter to 0775.
   create mask = 0700
# Directory creation mask is set to 0700 for security reasons. If you want to
# create dirs. with group=rw permissions, set next parameter to 0775.
   directory mask = 0700
# Un-comment the following and create the netlogon directory for Domain Logons
# (you need to configure Samba to act as a domain controller too.)
;[netlogon]
;   comment = Network Logon Service
;   path = /home/samba/netlogon
;   guest ok = yes
;   writable = no
;   share modes = no
[printers]
   comment = All Printers
   browseable = no
   path = /tmp
   printable = yes
   public = no
   writable = no
   create mode = 0700
# A sample share for sharing your CD-ROM with others.
;[cdrom]
;   comment = Samba server's CD-ROM
;   writable = no
;   locking = no
;   path = /cdrom
;   public = yes
# The next two parameters show how to auto-mount a CD-ROM when the
#	cdrom share is accesed. For this to work /etc/fstab must contain
#	an entry like this:
#       /dev/scd0   /cdrom  iso9660 defaults,noauto,ro,user   0 0
# The CD-ROM gets unmounted automatically after the connection to the
# If you don't want to use auto-mounting/unmounting make sure the CD
#	is mounted on /cdrom
;   preexec = /bin/mount /cdrom
;   postexec = /bin/umount /cdrom
Sandmanx,
That is really kewl!!!
I'm just starting to play with linux and this will help me a lot.
Mods....
Could we possibly get this added to one of the stickies and give a bunch of credit to sandmanx?
AtomicMoose said:
Ask and you shall receive. :D
Alright! I'm famous for my mad samba skillz now! :cool:
Like I said, I got it working right a couple of years ago and never jacked with the config again. Samba seems to be ultra-sensitive to changes in the smb.conf file. :(
yup, use a " /" insted of a "./ " and things go to hell.
AtomicMoose said:
you've just become immortal.
And maybe IMORALE too!!! :D j/k
But thanks, really, you deserve it.
Now if you can beat on u_m a little he'll get jealous and come up with something truly spectactular!!
