The situation: At my work our My Documents folders are all automatically redirected to user folder on servers, which is great. The bad, is that one of the LAN admins I work with is insisting that for folder redirection to work, the Offline Files feature must be activated. This causes all sorts of problems with folders and programs that run from the network becoming unavailable if there's a hicup in communication with the server. Getting the XP workstations to stop treating the files as offline is a PITA and drains alot of my time and the user's time.
Before this LAN admin told me to not disable it, I would disable the offline files feature on the workstation and not have to worry about this happening again. We have no reason to use offline files, (even per the admin) other than he insists that redirection won't work without it. The workstations where I'd already disabled offline files not only still redirect the My Documents folder just fine, but they are immune from the irritatingly frequent habit of XP to start treating files as offline.
The request: Does anybody know of an official Microsoft document where it explicitly states that Offline Files does not have to be active for folder redirection to work? Apparently the machines I've done this on that still work perfectly are not enough proof, and I can't find any official source that he might beleive.
