Demon10000
- Aug 20, 2006
I've got a problem with a machine. It's a Dell Laptop -- D505. I've installed a sysprepped XP on it using SCCM OSD and when it reboots to run minisetup it hangs.
I fire up safemode and I see the last few drivers are:
SISAGP
VIAAGP
MUP
ALIM1541
AMDAGP
AGP440
AGPCPQ
I assume is AGPCQP causing problems. I fire up the recovery console and disable it. Reboot and it hangs. So I fire up safemode again, and now it's stopping at AGP440.
Long repetative story short, I disabled everything up to MUP with a reboot to test each change and it always hangs at the driver before the one I just removed. Kind of tells me it's the next driver that is causing the problem.
I fire Advanced Startup Options (F8) and enable boot logging. I let it try and start and after it crashes (I let the thing sit for like 5 minutes) I fire up a WinPE install and look for the log file. There is no NTBOOTLOG.TXT file to be found anywhere on the drive. Because it doesn't create this file, I can't see what it's doing...
Any ideas on what I can do to find the next driver that is loading on the system? I don't get a BSoD -- it just hangs.
SISAGP
VIAAGP
MUP
ALIM1541
AMDAGP
AGP440
AGPCPQ
