WinXP Clock Wont Sync
mrlewp
I've tried repeatedly to manually sync my PC's clock , and the "error" message eventually pops up. Another oddity , the hour often reverts back one hour , and I have to go in and manually adjust it up. That's a new one for me.
Manually adjust the date as close as possible, then try again. Sometimes if you have the day or month wrong it won't sync.
Make sure your timezone is correct.
I had the same problem the error message doesn't appear now but the clock is usually 1 hour out, i dont know why though
the resetting hour seems like a daylight saveings time issue make shure its checked/unchecked depending on where you live... i would tell you what port to make sure you have open, but i cant seem to figure it out, it dosent seem to open a port... at least not that netstat live can detect any way (unless its just useing port 80 or something stupid)
thore
And the error message is.......?
