Greetings all,
I was wondering if anyone happened to have a solution for this particular problem. Last summer I converted my work network from an aging Novell Netware 6.5 network to an Active Directory structure running on Windows Server 2003 R2.
I've had everything working for a good 8 months and now that I know the base is working I've been trying to tweak it to get other features the way I want them.
I've had quotas set up for some time now - through the File Server Management tool. All users are however on soft quotas and are greatly abusing this. Getting tired of manually trimming their files so the server can actually back-up at night I've determined to fix the quota system into hard quotas - so they cannot exceed their allotments. Why I haven't done this yet though is that they have no way of knowing how much space they've used and whether they are about to exceed or approach their hard quota limit - which isn't exactly fair to them.
Now - I've seen the nice warning system that you can set in the quota management - when they hit certain levels you define.. ex: 90% it emails them. Problem being of course that A) My server is not setup for SMTP and I'd really like to avoid this at all costs and B) The users don't have e-mail addresses anyway.
Anyone have any ideas of a way to script a warning to them when they hit certain usage amounts? I saw something sort of promising in the quota management system - on the same window that you can setup the e-mail warning there is a spot where you can possibly run a command. Theoretically this could run a command or script or batch file that could possibly send a message to the user? Though I'm uncertain of this being true and how to deal with it if it IS true.
Even better I would like an application that sits in the system tray of the client machine and simply measures usage of their home directory vs an upper limit. I can see a few problems with this idea - but it'd be handy in the sense they'd have a constant warning of usage levels.
Now, I've seen a few applications that do something close to this - though they come at a rather dreadful price.
Any ideas out there?
Thanky~
Thanky~
