I conducted a highly unscientific experiment. It's only 1 sample, but it's interesting nonetheless.
I compressed two files. One is 109,369,344 B (.mp3) and the other is 1,230 B (.txt). Add them up and you get 109,370,574 B.
I used WinRAR 3.50 to make a .rar file. It took about 2 minutes to do and the final size is 109,342,218 B. The .mp3 went from 109,369,344 to 109,341,368. The .txt went from 1,230 to 695. I guess the rest of the file size is overhead.
I then used WinZip 9.0 SR-1 to make a .zip file. It took about 20 sec. to do and the final size is 109,147,612 B. The .mp3 went from 109,369,344 to 109,146,688. The .txt went from 1,230 to 662. I guess the rest of the file size is overhead.
So the .zip file is much faster and is even slightly more efficient from this one experiment I conducted. I thought .rar was supposed to be superior, at least for compression. What are your thoughts?
Edit: I used an optimized compression setting for WinZip but not for WinRAR. So after tweaking WinRAR's compression to "Best", I observed the following results.
t took about 2 min. 10 sec., to do and the final size is 109,331,174 B. The .mp3 went from 109,369,344 to 109,330,414. The .txt went from 1,230 to 605. I guess the rest of the file size is overhead.
But WinRAR, while slightly more efficient in compression, takes much longer to compress.
