Winner Declared in Space Elevator Race
HardOCP News
[H] News
A winner has been declared in NASA's Space Elevator Power-Beaming Challenge.
Held at NASA's Dryden Flight Research Center on Edwards Air Force Base in Lancaster, Calif., the challenge pits teams against each other to see whose robotic space elevator can inch up the cable the quickest in under 7.5 minutes. A helicopter holds the steel cable in place as each robotic elevator races to the top. The LaserMotive crew crossed the finish line four times, the fastest time being 3 minutes and 48 seconds.
What is the application for this technology?
Quite a lot. The article spells out one implementation with the "elevator" being used to carry payloads to stations etc. There are many others, just google "use of space elevators" etc.
By the way, GO SEATTLE! WOOO!
Huh, thats pretty damn nifty if you ask me. How much load can it carry? that is the true question if its viable or not
cost savings :) Without a space elevator, colonizing space is nothing more than a pipe dream. It costs a fortune to send rockets up there, building an elevator would be much much cheaper in the long run
This one basically wasn't carrying anything beyond it's own weight, up "only" 900 meters too. Baby steps though :). Think of it as more of a proof of concepts more than actual doing what they expect it to be able to do down the line.
Paraphrasing Michio Kaku and the Physics of the Impossible, a space elevator would rougly transform the cost of moving something into space from $10,000 a pound to $1 a pound.
It would constructed of carbon nanofibers that are essentially indestructible but the holdup now (even with this news) is being able to produce that many of them since nanotechnology is in its infancy, (even in its gestational stage)
Oh I am, they are still in the very early stages of exploration for the concept. Pretty cool though
love that man, just now starting to read physics of the impossible
I always pictured a space elevator on earth like as if Earth were holding a baseball bat. Smack those asteroids right back xD.
(Sorry for the non contributing to the discussion post ^^;)
Space elevator deflects asteroid, earth saved!!!!!!!!!!!
** worlds first space kitten was killed in the tragedy, story at 11 **
it baffles me how any cable could be strong and light enough to do this. they say carbon can physically do it though, well see. forget the strength at all, to think you can pull any wire out so far that a huge weight at the end will actually pull it away from earth solely because of how fast earth spins... its amazing.
I agree about the Baby Steps. That seems reasonably slow to me. 0.9km in 4 minutes? That's roughly 14km/hour give orr take a bit? So if leaving the earth is say 11,000 km since that would mean you've left 75% of the earth's atmosphere(Source: Wikipedia), you'd be able to reach outer space in just ... 785 hours or a mere 32 days.
Just imagine if they gave you air-plane food to eat on the way up and on the way down. It would be a fun trip with lots of awesome sights, but, you'd never survive off the nutrients/quality of food air-planes give you for 64 days :p:D.
This could spell the end of the airline industry. You can take the elevator up into space. Sit at the station while the earth rotates at 1000 mph until your destination is below you. Take the elevator or orbital parachute back down :)
hehe only problem is that the elevator is in a geosynchronous orbit. Its always in the same place anchored to the ground. :p
the station would be tethered to the earth :D
What the heck? How is this supposed to work? I suppose I could just do the math, but I'mma ask anyway. At what altitude is would Earth's terminal velocity match a sort of "terminal radians per second"? Only at that altitude would this start to make sense... and even without doing the math I can tell you it's TOO FAR FOR A ROPE.
well, considering the end of the tethered line would be traveling at around 18K miles per hour, re-docking wouldn't be very easy with a large structure :) some sort of shuttle would be more likely in a scenario like that
There is one major, and I mean major problem with the concept. It is a geosynchronous orbit project and how do you avoid all of the space junk out there? None of the junk is in a geosynchronous orbit. They are all moving pieces out there. It seems to me that the project would be totally impractical to operate over a long period of time.
The sight of a cable going into the heavens and disappearing behind the clouds must be just awe inspiring... knowing that at the other end, there is nothing holding it up but the centrifugal force of the earth itself..
All of you are thinking its for going up but no-one is mentioning how its a potent method of solving the problem of re-entry...
Um, how the heck do you get 11,000Km?
The space shuttle only orbits about 115-500 miles above the earth.
To me, 14km per hours is pretty dam good. Most terrestrial elevators don't even move that fast.
For you, and those to god damn lazy to google, the idea is you make the center of mass of the whole elevator be right at the geosync orbit... this is accomplished by having a heavy mass beyond it, with the rest of the mass being the elevator cables. Since the center of mass is at the geosync location the whole thing will rotate at the same speed the Earth does.
Also by having the mass further out it would naturally pull the whole thing up tension forces rather than compression by weight
The answer is simple. Space-junk wranglers with rocket jet-packs and ray guns and laser lasoos.
http://defensetech.org/2007/09/06/laser-plane-moves-closer-to-missile-kill-test/
A few of these systems mounted on the end in space should fix that quickly.
