I'm having this issue with a friend's computer. Every once in a while when I click on the Windows Update IE icon, Windows Update loads as it should. However, with enough time, it will quickly change into this link:
http://www.winfixer.com/download/2006?p=20&ex=1&ax=2&aid=vm_tx_vfx6kw_9&lid=error+winfix and the title will end up saying "Add/Remove Programs" which is a blatant lie.
NOTE: PLEASE DO NOT CLICK ON THE LINK UNLESS YOU ARE USING A TEST COMPUTER. I AM NOT RESPONSIBLE IF IT INFECTS YOUR COMPUTER.
I tried cleaning out his IE settings and running enough anti-spyware programs and this problem still occurs. I'm afraid it must've been hidden deep into his registry. Firefox works just fine however. Even though I can recommend him using just Firefox, I rather find the culprit and delete it for safety reasons.
Anyone got an idea?
Edit: I looked up and did some deep cookie hacking and came up with several ip's from winfixer:
64.125.84.23
202.67.220.227
62.4.84.53 (going there reveals a blank site that says "hi".)
And some IP look ups reveals one from Korea and another from Germany. Something tells me that either they're the ones that are doing it or their PC's are drones now? Correct me if I'm wrong.
-J.
Anyone got an idea?
64.125.84.23
202.67.220.227
-J.
