I tried the WinDVD 7 Trial version a few months back and I liked it, so I bought the Platinum version yesterday. I installed it, Activate it and then when I try to open the program, it does nothing! The sand clock icon (the one that appears when your PC is loading something) appears for like a fraction of a second and that's it, nothing else happens. If I put a DVD in it does the same thing, it just won't play it. I tried uninstalling it, cleaning my registry but no go. I'm very close to re-installing Windows, but I would like to solve the problem without having to do so.
I've read about other people having the same problem, but no one has the solution.
I already sent the inquiry to Intervideo by using their Tech Support Request form. As soon as I get a reply I'll post it.
If anyone has any suggestions, please post them.
