I am running a DFI LP 875b1 ( appears to be fine but only posts half the time ), 2.4 P4, 1gig Corsair 3200, Rosewill 500W PS, WD Raptor OS drive, 200g maxtor storage, Powercolor 9800SE 128mb.
So my problem is this. I am able to install Windows ( 2k and XP Pro ). By setting SATA mode to enhanced I can install OS to the Raptor and put NTloader on the 200g storage drive. The OS's will boot right after being installed. I load drives for my video card, Netgear wireless card, Saitek keyboard and the Motherboard drives. I reboot then install Windows updates, reboot once more and the computer comes up fine. I run it for an hour or more then when I try to reboot it starts hanging.
It will freeze trying to load XP in normal mode, 2k freezes at the "loading press F8 if needed" screen. In XP I can get to the boot options menu, when I try all 3 safe modes it freezes while loading AGP440.sys. Everything is brand new except for the motherboard, which I purchased from someone here. I have tried numerous settings in the BIOS and nothing seems to make a difference. DFI's website has no info and a quick search on Google reveals little. I can't figure out whats wrong or how I should go about trouble shooting this, I can't afford to replace stuff just top see if it works. Any Ideas?
Also, the motherboard only posts about half the time, I have to keep pressing reset until it comes up. What could be causing this, is it a faulty motherboard?
