Elmntskater1588
- Jul 12, 2004
Is this what you guys use to change stuff? Is there anything else out there? preferably free?
I have the patcher. Where are soem places to get skins? I get all of mine from www.interfacelift.com but there are only a few ones to look throughMet-AL said:http://www.neowin.net/forum/index.php?showtopic=140707
Neowin UXTheme Multi-Patcher v4.0
It allows you do what Windows Blinds does but for free and with no software running.
Instead of even going that route, you could simply replace the uxtheme.dll file using the recovery console.Met-AL said:http://www.neowin.net/forum/index.php?showtopic=140707
fuelvolts said:NO NO NO NO NO NO - do not use that craptastic resource hogging peice of crap. Anything that comes from stardock SUCKS.
/know from experience
