icehokplyr
- Oct 9, 2004
Okay, let's see if we can try and fix this one now.
I just built my new computer about a week ago. I installed Windows XP Pro. I also have an Abit AI7 Motherboard and one of the USB port drivers needed to be installed. I went to the Abit site, www.abit-usa.com, amd downloaded the USB20_2.22 driver. I saved it in my "windows", "options", "cabs" folder. The reason I saved it here is because it was already highlighted as a place to save this file.
After rebooting, and after about somewhere between a minute or two, my computer screen went blank and the machine restarted. When it re-booted, it said that Windows has recovered from a seriouse error and should be reported. The same thing happened again about an hour later.
Any advice or suggestions? Did I save the driver in the wrong folder?
Thanks in advance.
Thanks in advance.
