Windows XP Pro boots to blank screen?
fsi16v
The other night I was trying to update my nvidia drivers, and half way through the install I got an error and then it shut down my computer. Now when I try to start up windows, I get a blank screen. Just black, nothing on it. However, I can get it to boot in safe mode and show the screen, but then the mouse and keyboard do not work.
Is there any way I can fix this, or do I need to start fresh? :(
No onboard video btw
Get a PS/2 mouse and keyboard for safe mode. Or turn on legacy USB support in the BIOS, if possible. Boot into safe mode and remove the driver you were attempting to install. Use a driver cleaner if needed. Then you should be able to boot with a VGA driver, and attempt to load a working driver, even if you must go back to the one you had before attempting this.
