sitheris
- Jul 30, 2004
I am trying to setup some network shares on my server (Win XP Pro). All of my other computers run XP Pro as well. I have a public folder setup for everyone in the house to have access to..works fine.
I would like to setup a private share that only I can connect to by entering a username/password. I tried to set up a folder, I removed 'Everyone' from the share permissions, added the server username as the only one to have access. I left everything as-is on the security tab.
I can see the folder, but when I try to map it on another one of my machines, it doesn't like the password I give it. It prompts me with a login box over and over even though I type the username/password correctly. I am using <Servername>/<username>, and the password of the user on the server (The same user I added to share permissions earlier) as my login credentials and it just won't let me in.
Why won't this work....arghhh.
