Windows XP loads veeeery slowly - help!!!
bigweed
Hi to all. I have recently reinstalled XP Pro on my PC, done the usual video/audio/NIC driver updates, Windows Update, etc. The PC has been running fine for a few weeks now, but just a few days ago, it starts to hang on the initial load up screen. It stops at the point where it lists the BIOS version and the processor. It then hangs for about 20 minutes, and then goes onto the memory tests, etc etc. Has anyone come across this before, is there anything I can do to find out what the problem may be? All help most appreciated
Thanks
Bigweed
Only times I've seen a BIOS hang on a computer in my posession was when it was trying to read a hard drive that had failed. Check your Drives and make sure all of them show up in the BIOS properly.
Enable SMART on your hdd's to check for their health, though i highly doubt that thats the issue...generally your bios runs over the cpu, gpu, ram....does the ram check..THEN device checks..but it couldnt hurt to check...
also give your bios an update..maybe a cmos clear
GL&HF
Cata1yst
