I built two systems over the weekend. Both have Windows XP Home (SP2) installed. On the first system the HDD shows up as the usual C drive in "My Computer and Windows Explorer and the CD drive is the D drive. On the second system the HDD shows up as F Drive. C and D are some unkown USB removable devices and E is the CD drive. I do not know what those removeable USB drives are. I do have a card reader and front USB ports that are plugged into the USB connectors on the mobo, but nothing else. No pen drives or any other USB devices. Any ideas?
How does windows select drive letters? Do BIOS settings and order make a difference with Windows naming drives? When installingWindows, I didn't get a prompt to name my drive(s). Is there some way to reorder the drives so that the HDD is the C drive? I know that simply renaming the drive doesn't work.
